HP laserjet 3150
Er der nogen der kan fortælle mig om sådan en maskine kan køre med nummerbestemt ringning ??
Fladder
Kan godt ske det er mig der er ude af trit med fax-maskiner.. men hvad mener du med nummerbestemt ringning?
Mark Herskind
Det er noget teleselskaberne tilbyder - hos TDC hedder det nummerbestemt ringning - hos andre sikkert noget andet...
Det betyder at vi har to telefonnumre i samme stik (på de samme to ledere)
Hvert nummer har så sin egen ringe-karekteristik, hos os ringer den normalt ved telefon og med dobbelt hastighed når det er en fax - faxen genkender ringesignalet og starter øjeblikkeligt
Fladder
HP LaserJet 3100 and 3150 Series Products - Using Distinctive Ring Detection
Distinctive ring service
If subscribed to a distinctive ring service with a local telephone company, use this procedure to enable the HP LaserJet 3100 or 3150 series product to detect distinctive ring patterns. If distinctive ring service is not being used, do not change this setting, or the product will not be able to receive faxes.
Distinctive ring service is available from some local telephone companies in the United States. It allows having two or three telephone numbers on one line. This typically costs less than paying for two separate lines. Each of the telephone numbers will have a different ring pattern. For example, a voice number could have a single ring, and a fax number could have a double ring.
While distinctive ring service allows having up to three telephone numbers on the same line, the product only supports two numbers. The product cannot detect the difference between the double-ring and triple-ring pattern and would answer calls coming to both the second and third numbers.
If distinctive ring service is desired, call the local telephone company to check availability and to subscribe. (The local telephone company may use a different name for this service. For example, it is called "Identa-ring" in parts of New Jersey and "RingMaster" in parts of Florida.) This service may not be available in some areas.
NOTE: If subscribed to distinctive ring service, make sure that the telephone company assigns the double-ring pattern to the fax number. The product ignores the single-ring pattern.
Enable distinctive ring detection from the control panel of the product
NOTE: Only change this setting to "Yes" if subscribed to a distinctive ring service from a local telephone company. Do not change setting if not subscribed to this service, or the product will not be able to receive faxes.
[LIST=1]
[*] Call the local telephone company and subscribe to distinctive ring service. Make sure that the telephone company assigns the double-ring pattern to the fax number. There cannot be a third phone number on this line.
[*] Press ENTER/MENU.
[*] Use the < or > arrow key to select Fax Settings and press ENTER/MENU.
[*] Use the < or > key to select Incoming Faxes and press ENTER/MENU.
[*] Use the < or > key to select Distinctive Ring and press ENTER/MENU.
[*] Use the < or > key to select Yes or No and press ENTER/MENU.
[*] Press STOP/CLEAR to exit the Menu settings.
NOTE: If an answering machine or computer voice mail is connected to this line for the other phone number (usually on the single-ring pattern), make sure that the product’s number of rings to answer is set to a lower number than the rings to answer on the answering machine or voice mail. If it is not, the product will be unable to receive fax calls.[/LIST]
To enable distinctive ring detection from the JetSuite Pro desktop software[LIST=1]
[*] Choose Options from the JetSuite Pro Desktop menu. Access the JetSuite Pro Software by:[LIST=1]
[*]Using the Document Assistant
[*]Using the Program Manager in Microsoft (R) Windows 3.1x or the Start menu in other Windows operating systems
[*]Double-clicking the JetSuite product icon on the Windows Taskbar (at the bottom-right corner of the computer screen)[/LIST]
[*] Click Device from the dropdown menu.
[*] Click the Modify device configuration setting on the product window.
[*] Click the Advanced tab at the top of the product configuration window.
[*] Click the box next to Distinctive ring detection and then click OK .[/LIST]
Tusind tak for vejledningen......
Har prøvet at slå det til på faxen
Menu´en er fuldstændig som du skriver - men når jeg vælger "Distinctive Ring" skriver den "Distinctive Ring isn´t available"
Gør jeg noget forkert ?
Fladder
Kan du sige noget om, hvordan HP og telefon er tilsluttet? (telefon tilsluttet HP via stikket "L", osv)
