I Need help please with this
hi all i could be possibly working in Denmark soon , or I may be working remotely,so i would like the following translated .
The reason I am requesting this here is because i am quite sure that some of you guys here have pc skills , so could help me with a nice translation , mange tak PF.
It looks like the problem is a bad connection
I have changed the cables.
Thank you for your enquiry.
The issue is being looked at
I will send an onsite technician
I have resolved the issue
The problem was a configuration setting in the
The problem is a configuration setting
I will reply as soon as I can by phone
I will reply as soon as I can by email.
I tried to contact Lars but he was not there
I will call back later.
I have tried the following diagnostics /and checks
I have checked the following things on the system
I have resolved all issues on the server and created backups
The backups are being created
The backups may take 7 hours
The system appears to have a hardware failure.
The problem seems to be intermittent
This issue is being escalated
I will have to escalate this issue.
All the system settings seem to be correct.
I called but the Lotte was not there.
I have done a diagnostics check the result was fine /failure
I think the raid system is failing on the server
I think the hard drives are failing on the server
I think the back up system is good
I think the back up system is failing
The system set up is wrong
The hard drives are not compatible they are different types /sizes
The cable seems to be faulty
The cables are on the wrong way
I checked all the settings with the user
This issue is urgent it affects 700 users the issue is critical
This issue could potentially effect up to 3000 users , but at the moment 700 are affected
The system has been down for 2 hours
The fail safe system has not started
The fail safe system has started
This issue needs prioritising
I have tried changing the faulty part but it did not work
But it did not help
I talked to him /her
I emailed him /her
I emailed Mr./ Miss/Mrs
I need his contact details
I need their contact details
I will contact her later
He is unsure of what he did
He changed the settings
I will reconfigure the system
The server is slow
He is doing backups at busy times that’s why its slow
The operating system is corrupt
The operating system needs repairing
The backups are in place
The backup was successful
Please call if you need further assistance
Please call if you need more information
I will remote into your systems at this time and date and configure them.
Hi julietech
Did you get your text translated?
In that case I won't waste my time wink
If you have not, just give me a heads up, and I will get cracking biggrin
Regards Grandjean
Mvh Grandjean
My opinion is that Julie should pay a translator for this. One or two sentences is OK, but this...
Bent.
Nåeh, ikke andet....
Here you are Julie, have fun learning Danish....
Citat fra julietech
Det lader til, at problemet er en dårlig forbindelse
Jeg har udskiftet kablerne
Tak for Deres forespørgsel
Der bliver kigget på sagen
Jeg sender en tekniker ud
Jeg har løst problemet
Problemet var en konfigurationsindstilling i
Problemet er en konfigurationsindstilling
Jeg vender tilbage pr. telefon så hurtigt jeg kan
Jeg vender tilbage pr. email så hurtigt jeg kan
Jeg forsøgte at kontakte Lars, men han var ikke tilstede
Jeg ringer tilbage senere
Jeg har forsøgt følgende diagnoser /og efterprøvninger
Jeg har efterprøvet følgende ting på systemet
Jeg har løst alle problemstillinger på serveren og taget sikkerhedskopier
Sikkerhedskopierne er ved at blive lavet
Sikkerhedskopieringerne kan tage 7 timer
Systemet lader til at have en hardwarefejl
Problemet lader til at være periodisk
Alle systemindstillinger lader til at være korrekte
Jeg ringede men Lotte var der ikke
Jeg har lavet en diagnose og resultatet var (ikke) i orden
Jeg tror raid systemet svigter på serveren
Jeg tror harddiskene svigter på serveren
Jeg tror backup-systemet er i orden
Jeg tror backup-systemet svigter
Systemet er sat forkert op
Harddiskene er ikke kompatible - de er forskellige typer / størrelser
Kablet lader til at være defekt
Kablerne er sat forkert på
Jeg gennemgik alle indstilliger med brugeren
Det er en hastesag - den berører 700 brugere - sagen er kritisk
Dette problem kunne potentielt berøre op til 3000 brugere, men for øjeblikket er 700 berørt
Systemet har været nede i 2 timer
Det fejlsikrede system er ikke startet op
Det fejlsikrede system er startet op
Denne sag skal prioriteres
Jeg har forsøgt at skifte den defekte del, men det hjalp ikke
But it did not help
Men det hjalp ikke
Jeg talte med ham/hende
I emailed him /her
Jeg emailede ham/hende
Jeg emailede Hr./Fr./Fru
Jeg skal bruge hans kontaktoplysninger
Jeg skal bruge deres kontaktoplysninger
Jeg kontakter hende senere
Han er ikke sikker på, hvad han gjorde
Han ændrede indstillingerne
jeg konfigurerer system på ny
The server is slow
Serveren er langsom
Han tager sikkerhedskopier på travle tidspunkter - derfor er det langsomt
Styresystemet er ødelagt
Styresystemet skal repareres
Sikkerhedskopierne er på plads
Sikkerhedskopien blev udført med succes
Ring endelig hvis du har brug for yderligere hjælp
Ring endelig hvis du skal bruge yderligere oplysninger
Jeg kobler mig straks på dine systemer og konfigurerer dem
LuneLund: Once I thought I was wrong, but I was mistaken...
i was wondering if i would get a reply , i do appreciate this , thanks once again smile
thanks once again i do appreciate this ..
Sagen er under udvikling / optrapning.
Jeg må optrappe denne sag.
Hej julietech
Der manglede et par oversættelser i LuneLunds udmærkede bidrag. Håber du må få brug for dit danske sprog.
bodker
