Et nødråb fra en årgang 45.
Når jeg starter min stationære PCér kommer denne besked:
The TCP/IP network transport is not installed
Jeg kan ikke komme på nettet fra den maskine, men sagtens fra en bærbar.
Hvad er problemet?
bodker
Jeg vil gøre det kort. Løsningen er beskrevet nederst i dette link http://support.microsoft.com/kb/811259
Jeg har nederst i dette indlæg skrevet hvad du skal gøre.
Henrik
1. Click Start, and then click Run.
2.In the Open box, type regedit, and then click OK.3.In Registry Editor, locate the following keys, right-click each key, and then click Delete: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock2
4.When you are prompted to confirm the deletion, click Yes.Note Restart the computer after you delete the Winsock keys. Doing so causes the Windows XP operating system to create new shell entries for those two keys. If you do not restart the computer after you delete the Winsock keys, the next step does not work correctly.
Step 2: Install TCP/IP
loadTOCNode(4, 'resolution');1.Right-click the network connection, and then click Properties.2.Click Install.3.Click Protocol, and then click Add.4.Click Have Disk. 5.Type C:\Windows\inf, and then click OK.6.On the list of available protocols, click Internet Protocol (TCP/IP), and then click OK.
If Internet Protocol (TCP/IP) does not appear, follow these steps: a. Click Start, and then click Search.b. In the Search Companion pane, click More advanced options.c. Click to select the following three check boxes: •Search system folders•Search hidden files and folders•Search subfoldersd. In the All or part of the file name box, type nettcpip.inf, and then click Search.e. In the results pane, right-click Nettcpip.inf, and then click Install.7.Restart the computer.
Bingo.
Nu virker alt igen.
1000 tak.
bodker
