Loftslampe i en gammel lejlighed Pipo373 5 10-08-2022 21:01 Hi! I am trying to install loftlampe in our new(very old) place, how do i access cables in here? Should I be able to unscrew the botttom part? It is freshly painted so its difficult to see 8 svar Følg tråden Annonce Annonce Annonce
cdp 1042 5792 10-08-2022 21:54 Hi - this is translated on google.If you live in an apartment, get the landlord to install a new box. A suspension hook in the middle of the cover almost calls for an electrician.Kindly hiss
Pipo373 Trådstarter 5 10-08-2022 22:09 Hi and thank you! its a place we bought so I would have to get and pay an electrician to come in an install it myself. I know the previous owners were using the box up there, so it should be possible LDS Tip Automatisk tip Se ugens tilbud på lamper og belysning hos Harald Nyborg
cdp 1042 5792 11-08-2022 07:44 The picture is a bit unclear, but the type of wire comes through the pipe and into the box, disconnect the current on the residual current relay or fuse group first, unscrew the hook and see what is hidden inside. Take a picture of the inside of the can. Can be both a passage to another installation or just 2 wires. If you can't get the can open this way, clean off all the paint and locate the screws. Paint must be on the ceiling and not on installations.
Kristian1 8 2200 11-08-2022 08:07 The two wires from the lamp should go in from the front, and you should have access to a small screw terminal from the holes on the side.There should be two holes on the side
Pipo373 Trådstarter 5 12-08-2022 18:47 Hi all, thanks a lot! I managed to get in by unscrewing the hook as you suggested. This is how the cables look inside. I can also access the screws on the edge to attach the cables after I cleared the paint.Is it possible from this to figure out which wire (blue/brown) goes where from the lamp? Do you think I should rather get electrician to replace this before I use it? Thanks again! LDS Tip Automatisk tip Se ugens tilbud på lamper og belysning hos Harald Nyborg Annonce
ev elmand 26708 7480 13-08-2022 12:11 The color dos´t matter. You have 3 wires with the same color so you must try. There is no risk at all. Har nogen samlet det, kan det skilles ad. Samles igen ? ?m.v.h. Erik
kaffemand 435 4100 13-08-2022 12:16 How many switses are ther on on the wall, it could be an chandelier switch.
Pipo373 Trådstarter 5 14-08-2022 13:16 Just one switch for the lamp. Will try different options, hopefully one of them will work. Thanks!
