Faldt over ovennævnte i seneste Bygma salgsavis - er der nogen der kender den?
Der er tale om en centralstøvsuger som også kan bruges som mobil støvsuger. Pris 4999,- (op til 150m2)
Power, Pmax W 1500
Voltage V/~/Hz 230/1/50
Vacuum mbar 230
Air flow rate l/sec 60
Container volume l 27
Dimensions LxWxH mm 390x380x570
Weight kg 10
Due to the healthy benefits it brings and due to the smarter way of cleaning - once that you have tried it, you will not be able to live without a central vacuum system!
Clean & Healthy, dust and odour will disappear out of the house
Quick & Easy, only carry the flexible hose around with you when you vacuum the house
Silent & Comfort, You only hear a silent whispering while you are vacuuming
CENTIX 60 has wheels, and can there be used as a mobile vacuum cleaner as well, vacuuming you car, basement etc.
CENTIX 60 can be installed in old as in new houses. A detailed installation guide is included in the packaging. Plan a DIY weekend for the installation.
Two boxes are needed for a complete CENTIX 60 system One box with the vacuum unit, inclusive all parts for connection to the installed tube system and for directing the exhaust air out of the house, wall mounting unit, 9m hose, telescopic extension tube, 4 nozzles, filter bag etc. ALTO Installation kit, including all what is needed for a good and easy installation of the tubes in the house, including a detailed installation guide. Installation Kit 2, with 2 inlet valves, 12m tubes etc. for houses up to approx. 150m² Installation Kit 3, with 3 inlet valves, 18m tubes etc. for houses up to approx. 250m²
