Hi, we have a bought a stråtage bindingsværkshus, which is from 1810. Now the problem is that it need isolation from outside. We really do not know what to do, since one guy was out looking at the outer wall isolation, and the solution he gave is to isolate the house with 100mm (10cm) with STO Therm mineral. But he mentioned that he will not be able to isolate from where the sokkel start till the ground, because the house is old and base/sokkel is built with stones, so they can't cut the stones, and neither they know how many stones are there, in which direction they are laying, and how dangerous it can be to cut these stones and dig down so to make it possible to do isolation all way down. There fore if STH therm mineral solution is implimented then there wil be a kind of cold bridge created, which will don't look good as isolation not going all the way down, and also there will be still cold or humidity coming from base. And even if we found some one to do the cleaning of stones and cutting stones it will be really expensive. So is there any other solution to isolate a bindingsværkshus which may give some better way to isolate the old house and make it a bit more secure from fungus and as such? Any help will be highly appreciated.
