havetraktor går i stå når bremsen slippes
Hej!
Har en partner p1292 havetraktor.
Motor starter og kører fint i frigear når parkeringsbremsen er slået til.
Men så snart parkeringsbremsen slås fra (dvs. drivrem kobles ind) går motoren ud efter få sekunder, i.e. som om den ikke kan klare belastningen.
Hvis man inden den går ud aktiverer parkeringsbremsen kører den fint igen.
Har checket rem og remhjul – alt OK. Remmen og hjul kan drejes med hånden selv når bremsen er slået fra.
Samme problem med og uden klipper, så p.t. er klipperen taget af.
Nogen ideer?
Fra nettet er forslaget at checke sædekontakten, så det prøver jeg først.
ref. http://www.shopyourway.com/questions/1130702
Thank you for your question.
Your Tractor uses an Operator Presence (seat) switch that will cause engine to stall if blades are engaged or the brake is released without anyone on the seat. If ample amount of weight is not kept on the seat during operation or the operator is leaning forward the tractor will stall because the Operator Presence (seat) switch senses that the operator is not completely on the seat.
To check Operator Presence (seat) switch:
Lift seat.
Locate wires that connect to Operator Presence (seat) switch under the seat.
Disconnect and clean any debris in the switch connector. Use an ohmmeter to check the switch. When the switch is not pushed, the reading should be 0 ohms (closed). When pushed it should read ol ( open load )
Make sure the connector is fully seated on the seat switch. The connector is a special connector that will short the two wires if it is not fully seated.
I hope this is helpful.
Please click on the following link to order the parts you need.
Sears Parts Direct
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:
Sears Home Services
Please let me know if you need further assistance.
Thank you for using Mange my life.
Mark T.
og det løste problemet...
Ja når vi er så langsomme til at komme frem fra "hullet", er det da godt du kan SELV.
Mvh. Leif.
Onliner:
