Corn beef
Er der nogen der kan forklare mig hvad corn beef er og er corned beef det samme.
på forhånd tak.
mvh
Max :-)
Jeg har aldrig hørt om andet end "corned beef", som er sprængt
oksebryst, men det kan nemt lyde som "corn beef" hvis udtalen ikke er
meget præcis. Her er en opskrift fra Mortens samling:
Corned Beef
Ingredients (12 servings)
8 lb Brisket; boneless
1 c Salt
1/2 ts Sugar
2 tb Mixed pickling spices
1 Garlic; the whole head
1/4 ts Saltpeter
1 pn Alum
Instructions
Place brisket in a large stoneware crock and cover completely with
water. Add remaining ingredients, stirring to distribute them evenly
(I would add more garlic and more peppercorns; never enough in the
mix) Let it stand at room temp for 4 days. place in the fridge for 16
days. Remove from the crock and place in a large kettle. Cover with
boiling water and boil for 1 1/2 hours. Turn off heat and let stand in
water in which it has cooked for at least 2 hours. Remove meat to
another deep kettle. Place in sink and let cold waater run into the
kettle (not directly ON the meat) for 1 hour. (this seals the meat
juices) Remove brisket from the water and refrigerate unntil ready to
use. If you serve hot; steanm...do NOT boil.
Kvan.
