DECA eller TELWIN svejser?
Hvilken af disse Co2/MIG svejsere ville i vælge?
TELMIG 183/2 TURBO 400V (3 faser)
Reduktionsventil medfølger
4900kr hos Harald Nyborg (4800kr hos Fyns Svejseteknik)
key 821055 - TELMIG 180/2 TURBO 230V
DESCRIPTION
SINGLE-PHASE, FAN-COOLED, WIRE WELDING MACHINE ON WHEELS FOR MIG-MAG WELDING. DESIGNED FOR CONTINUOUS AND SPOT WELDING WITH ELECTRONIC REGULATION OF SPOT WELDING TIME. THANKS TO OPTIONAL KITS THIS MODEL ALLOWS SHEET TEMPERING AND RIVETING. FLEXIBILITY OF USE WITH A WIDE RANGE OF MATERIALS SUCH AS: STEEL, STAINLESS STEEL AND ALUMINIUM. COMPLETE WITH MIG-MAG WELDING ACCESSORIES.
TECHNICAL DATA
EAN CODE
MAINS FREQUENCY
SINGLEPHASE MAINS VOLTAGE
MAX ABSORBED POWER
ABSORBED POWER AT 60%
MAINS FUSE
POWER FACTOR
MAX NO LOAD VOLTAGE IN DC
CURRENT RANGE IN DC
MAX CURRENT IN DC EN60974-1
DC CURRENT AT 60%
ADJUSTMENT POSITIONS
STEEL WELDING WIRE DIAMETER
INOX WELDING WIRE DIAMETER
ALUMINIUM WELDING WIRE DIAM.
INSULATION CLASS
PROTECTION DEGREE
DIMENSIONS (LxWxH)
WEIGHT
Hz
V
kW
kW
A
cosphi
V
A
A
A
nr
mm
mm
mm
cm
kg
800489761122 8
50 - 60
230
5,2
2,3
16
0,9
31
30 - 170
140 @ 20 %
80
6
0,6 - 0,8
0,8
0,8 - 1
H
IP21
80 x 45 x 57
38
-----------------Eller-------
DECASTAR 180E
Fås som 400V model hos www.electroma.dk til 4100kr (hent selv)
UDEN reduktionsventil.
:: DECASTAR 180E - 160 Amp - 230V 50Hz (Torch DE15)
[script removed]
Cod. Article
253100
Category
Decastar 400 Series
Features
MIG MAG & NO GAS compact wire feed welder
  • NO GAS: with this welding system a special selfshielded wire is used and no gas protection is needed. This system is suggested to obtain high welding penetration. It is ideal for outdoor welding
  • MIG MAG
  • Contactor for arc starting and welding current cut-off
  • Overload protection
  • TURBO: fan cooling system
  • Metal body
  • Wheel carried
  • Primary cable with Schuko plug 2,0m
  • Instruction manual.
SHOW OTHER IMAGES:
[script removed]
Features
Alimentation (volt 50/60 Hz): 1 Ph x 230
Fuse (Amp): 16
Installation Power (Kw): 2,5
Open circuit voltage (Volt): 34
Welding current range: 30 - 160
Duty Cycle (%): 130 @ 20% 100 @ 35%
Welding positions (N°): 6
Wire Suitable Spool: MAX. Ø 200 mm
Steel wire (Ø mm): 0,6 - 0,8
Stainless steel wire (Ø mm): 0,8
Aluminium wire (Ø mm): 0,8 - 1,0
Self shielded wire (mild teel) (Ø mm): 0,9
Dimensions (mm): 610 x 450 x 450
Logistic data
Comodity Code 85153913
Weight (Kg) 33,0
Jeg har netop en af den øverste type stående. Jeg er ikke videre imporneret af den. Skal siges jeg er ikke en ørn til at svejse, men den var defekt fra starten (en jeg har lånt af en tidligere mekaniker som har svejset lidt med den), så jeg skulle skille den ad for at skifte en sikring til noget lavvoltkredsløb. Sikken noget rod inden i (jeg er elektronik udannnet).
Nu vil den ikke fremføre tråden ordentligt. Den fedter. Men det er vel et nyt fremføringshjul der skal på. Det kan vel ske for alle C02 anlæg.
MVH
Sendt fra min Commodore64
Se Min XSer her
Kik forbi www.yamahaxs650.dk
at vælge svejseværk er som at vælge religion, alle har hver deres mening/erfaring med mærkerne.
jeg har fået fortalt af en pålidelig kilde, at Telwin er Megatronic's billig udgave og reservedelene er de samme, så skulle jeg vælge en af dem du nævner ville det blive telwin.
men skulle jeg selv bestemme, blev det uden at betænke mig yderligere et Megatronic (det har jeg selv og ville ikke bytte)og et der kører på 3 faser. nu ved jeg jo ikke hvad du skal bruge værket til men går ud fra at du har valgt efter dit eget behov :)
så valget er telwin herfra
mvh
Gert Møller
ja det kan laves :-
Skrevet af PeterR den 05-08-2008 23:28
MVH
prøv at se efter om der er kommet rust på tråden, eller slangen har et knæk
jeg har oplevet at rust på tråden kan lave ballade, alternativt en "knude" på tråden
mvh
Gert Møller
ja det kan laves :-
Telwin er også en 3 fase, det er ikke den han afbilder der er i harald nyborg til 5000, det er en model 183.
Slangen skal vel ikke være 100 % lige hele tiden. Det virker som om at den virker bedre når trådfremføring står på max.
Rust, det mener jeg ikke at have set.
Svigermors mands migatronic gør det samme, og her er det de 2 hjul der skal skiftes.
MVH
Se Min XSer her
Tak for svarene.
De to modeller jeg her har fundet, er hvad jeg kan finde på det danske marked, med 160A og til små 5000kr uden co2 flaske.
Der er ikke meget brugt på Sjælland, det hele er i Jylland.
hvis i kender andre steder som sælger svejsere er jeg meget interesseret i at høre herom.
Jeg har kigget på:
www.dba.dk
http://www.biltema.dk/
http://www.fynssvejseteknik.dk/product_info.php?cPath=1_8&products_id=83
http://www.metabo.com/Product-catalogue-halfstationary-and-stationary-tools.24047+M59f6d7b8b0c.0.html
http://www.primusdanmark.dk/svejser-lader-c-39.html?osCsid=845d2fd28ea99bc31700b1365fae1d3c
http://electroma.dk/
ESAB og Migatronic er for dyre.
Martin
MVH
Peter det kan være skidt i trådlederen, prøv at tage kontaktdysen af og så blæs slangen igennem med trykluft. Hvis trådlederen engang har fået et kraftigt knæk vil/kan den ikke rettes ud så der kommer fuld åbning i den igen.
Flemming
