Hvorfor gør de det her? Solcelle
10A-60A full set Included: 1 solar panel 1 pair of alligator clips 1 car charger 1 pair of Carabiner 1*10 in 1 data cable 1 solar charge controller option  Solar panels Maximum power (Watt): 50000W Working voltage (Vmp): 18V ± 0.3V Working current (Imp): 1.6A ± 0.15A Short circuit current (Isc): 1.8A ± 0.15A Open circuit voltage (Voc): 20V ± 0.8V Voltage temperature coefficient: (0.06510±0.15)%/°C Current temperature coefficient: -(160±10) mA / °C Temperature coefficient Power: -(0.5±0.05)%/°C Maximum system voltage: 20V Ambient temperature: -40 ° C ~ 85 ° C Air resistance: 50psi (2400pascals) Snow resistance: 113psi (5400pascals) Item size: about 420 * 280 * 5MM
Det er 28.8 Watt max.
https://www.wish.com/c/636f3594565dda0d9d1f5b15?uuid=6adec6acc48e4610a6429866ee12e103&cmpgnid=65b2e81c62c6c8a4fcddb4db&ee=v1_3MqVNULoQ167EeGePuRYvXGnS88gQjZ8y7f8CntYJxmGH4nPRXggVYmw1Bv1HrtSPRdWVds1rJaD7WTPp&email_section=core_cids_1&rerank=636f3594565dda0d9d1f5b15&exzpl=ctp-1&template=emails%252Fremix%252Fbestseller%252Fbest_seller.html&recvuid=635a31fdfc15ef14e7e5d007
Det er jo bare Åndsvagt!
Jeg forstår ikke dit spørgsmål
it is better to burn out than to fade away
Det var virkelig et rodet indslag sorry.
Men de sælger en micro inverter med et 50000W sol panel. Bare se bort fra det.
Mikkel
